I'm not a big Navisworks user, but have a model done in Navisworks and I need to get 2D flatshots of it for AutoCAD. I've imported in into AutoCAD a couple of different ways, but neither way provides solid componants to get a flatshot from. Anyone know how to help?
The only 2D that I am able to export is a JPG file.
You could insert that in AutoCAD and move and scale it until it is somewhat correct, but it will never be complete accurate.
In AutoCAD there is the EXPORTLAYOUT command to save the Layout of a 3D DWG into a new 2D model, but I doubt if that workaround could help you.
Check your contract to see if you have rights to the original model or associated documents. If you do, let the provider know. If you don't you're pretty much SOL. One of the things about Navisworks is it lets providers share content with less concern that others will attempt what you are trying to do e.g. that model could be well out of date or never intended for use/not engineer approved.
Yeah, I'm thinking it's not going to work. I'll just have to figure out another way to do this. Thank you for your response.
