The default thickness setting appears to be 3.
I prefer 5 as it is easier to see in viewpoints, but I cannot locate where the default is set at.
I tried changing it after deleting lastsession.xml to see if that would change it (doesn't) and also
tried saving out my workspace with this setting to no avail.
Ideas?
Perk
Solved by alan.quinn. Go to Solution.
Please go here http://docs.autodesk.com/NAVMAN/10.0/ENU/Autodesk%20Navisworks%20Manage%202013%20Online%20Help/index...
and do a search for Redline Tools Panel
Thank for posting your question,
Thanks, but I already have that info unless I'm missing something that you were trying to show me.
I have to change it in every drawing every time that I open it or them.
I was hoping for a global default setting for this in the advanced options editor or elsewhere.
I found this option, but it always defaults back to 3 no matter what I change it to.
Perk
Do you have a global options XML file in one of the search locations? They always seem to work for the things that I don't want to manage, and not work for the things I *do* want to manage.
