Hi there
I have a Ifc File from an Architects. He use Archicad for his work. So is there a chance to get the Room tags visible in the Navisworks Model? In the Solibri Model Checker you can see the Room Numbers and Names in each story. These helps a lot to have an orientation in the model.
Thanks you for every useful answer.
best regards
chris
Hi @christof.raess,
yes, you would be able to see the tag within the properties panel. You just have to play around the different levels inside of the selection tree because each level has different properties.
At your disposal
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Thank you for the answer. My goal is to have the same or a similary result as in solibri. ist that possible the way you explain?
best regards
chris
Hi @christof.raess,
it is possible yes, because Navisworks reads IFC properties, but it won't be displayed the way you see it in Solibri.
You will see this tags in the properties panel.
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
