The issue: Navisworks does not show some Plant3D properties such as the "Weight".
Is there a way to directly read in and display the "Weight" property from P3D drawings when loaded into Navisworks?
Solved by dave.wolfe. Go to Solution.
Thank you @NotFromFrance,
this way other people may find it in an easier way.
By the way in the meantime I was wondering why, and then I remembered I had the same issue with another program.
Check out this for Plant3D.
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Already have the object enabler installed for Plant3D. I need to get the "Weight" property of pipe/inline assets (from Plant3D) to display in the Navisworks properties.
If there isn't a direct way to read in this property...(ie: by setting up a new link to the Plant3D object database and/or using an SQL query for the weight property), then my solution would be to export a list of all the pipe/in-line assets within each drawing into an Excel spreadsheet with a column for the Tag# and another for the Weight. Then I'd be setting up a data link inside Navis for the Weight value in the Excel spreadsheet.
The Navis model can then be saved to NWD using the Embed Data Links option, then sent on to the engineer who needs to see the "Weight" property while he reviews the piping system.
The other thing that comes to my mind is to have you update everything.
https://knowledge.autodesk.com/support/autocad-plant-3d/downloads
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
"Everything" was updated yesterday. I edited my previous post...could you look into doing it that way for me?
I could also develop a plug-in that opens up the source dwg file in Plant3d for each Navisworks object of Pipe/PipeInlineAsset type, and then read in the weight and then add that property to the properties in Navis.
This is not a bad idea, but it is a workaround. Let me get deeper into this and dig other ways.
In the meantime I would like that @Azmeera.M and @philip.s may have a look at this.
Thank you so much
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Want to present in Infraworks? Vote this up!
From what I remember, that "Embed Data Links" doesn't work in Freedom - it only works of the NWD is opened in Simulate or Manage.
While Excel is great for human readability, it's a bit clunky for querying. If you have to it this way, I'd recommend a database. If you want to get really clever, use a global part coding system in your models. Then establish an external database (SQL Server or better - MS Access would be a bit dodgy at this level) with cost information, order time, *weight*, and other properties that don't necessarily affect 3D design, using that part code as the key. Not only will you get access to that information in the Navisworks model, but other departments such as estimators can run their own queries as well.
Right, "Embed Database Properties" is the correct term, and it's an option when publishing to NWD, which can only be done in Simulate/Manage. As long as I get the property I want added in the .nwf, I can then export to .nwd and they'll show up. Whether I do that through a database or through a .NET plug-in...either way is a work-around. We're getting there, just wish there was a more direct way. The information is already in Plant3D...Navisworks just has to access it.
Hi @dave.wolfe,
I knew it there must be an app!!! You are the man! 😃
@NotFromFrance it is just a matter of will and digging 😃 Sorry I couldn't help more
Have a wonderful week guys
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
HI dave.wolf
Can this application be downloaded when you download it?
or do you have to acquire a license for each one?
can be applied by the administrator and so the other users see the PLANT 3D tab in NWD sessions
Thank you
I no longer work for ECAD so I'm no longer in charge of that product. However, it is license by machine. You can register and release licenses from the plugin ribbon panel.
Hey guys, has anyone gotten the Fasttrack plug in to work? Do I need to do something in Plant before this will run?
I purchased this plug in but cannot get it to run. There is very little info on how to install. Does anyone have an Ecad contact or could give me some tips? I have written to Ecad a few times with no response.
Thanks!
Hmmmm.....I don't think I have the full download. See screen grab of what is in the folder.
So you didn't use it long. Was it not what you expected? Have you found another way to get more data over from P3D?
Thanks so much.
You can email support@ecadinc.com for support. When I wrote the plugin, I had no idea of the headache that developing for Navisworks would become. We had issues with Navisworks service packs breaking plugins, the installation location has changed 3x over the years, and every version needed its own build. The DWG doesn't embed the data, so every solution requires loading the data from some other method (code, odbc, etc).
Thanks Dave,
Very helpful as always! I will let you know if I hear back and get the plug in working.
In the meantime I am working on using Data Tools in Navis. But for that to work, I think I need to switch over to Office 64 bit. Frankly I am dreading that and have held off.
Erin
Mira este link.
Saludos
J.Canales
