I have a Revit 2017 file of a building that I've opened in Navisworks 2017 and I want to override the color of the MEP elements while keeping the appearance of the Revit materials on the architectural components. If I am on Full Render mode then I get the Revit materials but cant override colors, if I go to Shaded then I can override the colors but I lose my Revit materials and most of the model components turn white. Is there a way to show Revit materials and be able to override appearance?
Here's a side note that may be relevant: When I select a model component and look in Properties Window> Item> Material, I am finding that most of the time it says : "*Component Type - *System Type - <Material parse failed>". For example, when I select a piece of duct in my model, and look towards Properties Window> Item> Material, I see: AHA - Duct - Supply Air - <Material parse failed>".
Thanks in advance for any advice on this topic.
Solved by Patrick_Aps_9121. Go to Solution.
Thanks for the reply, I guess I'm trying to have my cake and eat it too here. Regarding the second thing I mentioned, does this message "<Material parse failed>" mean anything to you? Could it indicate that something went wrong when I imported from Revit to Navisworks?
