Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Objects with Multiple Instances
6 REPLIES 6
1255 Views, 6 Replies
When hiding a search set, a pop up message states:
"You have selected an object which is instanced multiple times.  Performing this operation will change all instances of the object, not just those that are selected."
If you select OK, some items, which were not selected are hidden (as warned)...
Is there a way to change settings so that only objects selected are hidden?
Tags (1)
6 REPLIES 6
Patrick_Aps_9121
I can only guess,
but it will depend on the program used to create the objects.
In case of a Autodesk vertical (Program on top of AutoCAD), the following solution might work:
- Open the DWG with plain AutoCAD, without any "object Enablers" installed.
- Save it in an older version of AutoCAD, like 2000 version and try this version later
- Use Qselect to select all Blocks and Explode them. Purge the drawing
- Save the drawing with another filename, so you can use this 2nd copy to try also.
in reply to: Patrick_Aps_9121
The objects in this instance are from Revit...plus that sounds like a painful workaround, when there should be a solution within Navisworks.
dembkod
Hello ScottWood8135 ,
This should be simple and there should be no need to resave a new file.
Have you tried selecting your item at a different level of the selection tree? I ran a test for you and I seem to be okay when I do this. If you are selecting your item from the selection tree, select one level higher and hide the item, it should hide.
If you are selecting in your workspace and hiding, and it hides all of them, your “Selection Resolution” is set wrong.
1.)   Click the Home tab.
2.)   Click the drop-down arrow at the bottom of the “Select & Search” section.
3.)   Change your Selection Resolution” to “Last Unique”.
Now when you click an item and hide it, it only hides the unique item.
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
in reply to: dembkod
Thanks, but not quite there.  My Selection Resolution is set to Geometry, which is more granular...
The issue is with Hiding Search Sets...if the items are selected any other way, the issue does not occur.
That being said, I'll can figure out a way to hide the objects, without using the Search Set to select...this is one of those acceptable flaws in the software.
INTOOCAD
I am curious as to if there is any other solutions to this. I am having the same problem.....
Thanks!
in reply to: INTOOCAD
I am experiencing the same issue.
I am attempting to use a selection set to select objects in the first tier of the heirachy, and all siblings. The search set works fine, and selects the correct geometry, yet returns the error when trying to 'hide selected' or 'hide unselected'
If I manually select the branches I want, they will hide no problem.... Eeek
Rail Community
