ive spent the last week trying to import IFC objects. Not sure who said these 2 were compatible. We have exhausted all options, updated IFC exporter, imported to Revit and used the Native NWC export utility. The objects just dont come clean.
I'm having the same issue. Navisworks doesn't show some object that are in Solibri visible.
Anyone any idea?
Same Issues here. I ended up having design team export an NWC file straight from ArchiCad. we could not get the model to import. Also had to export IFC for the glazing and windows. Some reason NWC exporter for Archicad would not export them either.
Hi.
We recently released Navisworks 2017.1 to subscription customers. It contains a new IFC loader that should significantly enhance the fidelity of Navisworks with IFC files. More information can be found here: http://beyonddesign.typepad.com/posts/2016/09/announcing-navisworks-2017-update-1.html From the sound of the posts in this thread, I would expect it to fix these issues.
Please give it a try and hopefully it will resolve your issues. If not, then please let us know and we can log the issue and track its resolution.
I hope this is helpful to you,
J
The new functionality 'Revit_IFC' in the options of Navisworks 2017 update 1 solves the issues.
The only problem I have with this result is that the levels are missing in the Selection tree and that my Property Sets are gone. See image.
Hi Joris.
Thanks for the feedback, really happy it worked.
Appreciate you taking the time to feedback the additional issues too. We've logged them in our issue tracking system and will begin to investigate with a view to fixing if practical. I'll track this thread so we can notify you if/when that happens.
In the meantime, please note that info is in the models, its just not organised where you would expect it in the selection tree and in the properties. Hopefully you'll be able to work around this if you decide to continue using this loader.
HAGW.
J
Dear Navisworksteam,
I have similar problems with the Import of ifc-data.
The ifc contains rooms and spaces, but in Navisworks the ifc-information was lost.
I am using Navisworks Manage 2017 incl. Update 1. The Revit-ifc does not solve the Problem.
It would be fine, if you can help me.
Thanks in advance.
A. Tigges
Was the solution specific for IFCs from Revit or was it for all IFCs regardless of origin?
We are also having the same problem with IFCs from TEKLA software. Where object/s can be seen on TEKLA's default viewer (BIMsight) but are not reflected in Navisworks.
Please help.
Thank you!
Jesse
I have noticed that some IFC object with a great length doesent show up in Navis but is clearly visible in solibri. Try divide your object and do a new export to see if you have the same issue.
I had an issue where IFC objects would not show, when they had an ' in the name. (from Archicad to ifc in to Navisworks)
Hi everybody.
So guys, which is the final result? which do you think is the best way to move things from Archicad to Navis?
Best
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
I think there are 2+ issues here.
For geometry, it's much better in 2018, but I would not recommend using the "Revit IFC" check-mark. It kind of makes it worse, not better.
I usually turn the subdivisions factor to like 3 and it works fine.
Now it is 2018, but yet I have this problem. Do we have a workaround or a solver for this? 🙂
I am also seeing the same issues with 2018 Manage and Tekla IFC files (IFC2X3). I can change the option to "Revit IFC" but none of the assembly information is retained. Have there been any workable solutions presented? I may be forced to use some other review software at this point.
We still have to use this workardound:
IFC files are missing properties, elements or components in Navisworks
