Dear all,
I am working on a application with two versions.
One is using the DLL of Navisworks 2013 and the other one is 2014.
In API, there is one method for us to save the file, as below.
Application.ActiveDocument.TrySaveFile(serverPath, DocumentFileVersion.Navisworks2013);
If I open the model with the API in Navisworks 2014 and save the model in 2013, is there any changes on the model?
I am also curious after I save the model in 2013, is there any changes on the model structure if I open it with API in Navisworks 2013?
Best Regards,
John
Solved by xiaodong_liang. Go to Solution.
Hi Xiaodong,
Thank you for your information.
May I ask two more questions?
Best Regards,
John
Hi John,
Which format you are working with?
Hi Xiaodong,
Thank you for detailed answer.
May I confirm that there will be no differences on model structures for saving models in 2013 and 2014 version?
Best Regards,
John
Hi Xiaodong,
Thank you for your action.
I concentrate on whether there are any changes on the selection trees.
John
