Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Timeliner x Rules x Find Items
2 REPLIES 2
mauricio_antonini
541 Views, 2 Replies
Hello to all!
I am willing to write an API code to achieve a very simple and tedious task with Navisworks Timeliner but before I start to dig into it I wanted to check with the experts if that is even possible considering the API available today.
What I want:
I want to attach tasks to items. I know there is a feature for that. To be more specific I need to create rules to auto attach them. I also know that there is a feature for that. What I really need is to apply multiple rules at the same time just how FIND ITEMS works.
For example: attach the task TOWER 1 - LEVEL 5 - Wall Type ABC to elements which ITEM LAYER = LEVEL 1 AND ITEM FILE NAME contains TOWER 1 AND ITEM NAME contains Wall Type ABC
Today it is not possible (as far as I know) to do that natively. Would it be possible through API?
I've searched the forum for similar posts without success. I am sorry if I missed something.
Thanks in advance.
Eduardo Tavares
2 REPLIES 2
probably I do not understand correctly, but the TimeLinerTask.Selection could be a Search: TimeLinerTask.Selection.Search.
So you should be able to setup a search (with searchcondition).
Can this be helpful to you?
Thank you, Xiaodong!
I will try that out soon.
Eduardo Tavares
Rail Community
