Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
the problem about timeliner
3 REPLIES 3
suzipeng
522 Views, 3 Replies
i created a project in vs2012,import three dll,
 Autodesk.Navisworks.Api;
Autodesk.Navisworks.Controls
Autodesk.Navisworks.Timeliner
and also using the namespace in programm
using Autodesk.Navisworks.Api;
using Autodesk.Navisworks.Api.Controls;
using Autodesk.Navisworks.Api.Timeliner;
but when i run the programm, the system prompt the error as
未能加载文件或程序集“Autodesk.Navisworks.Timeliner.dll”或它的某一个依赖项。找不到指定的模块。
actually, i can find the dll in my computer
i also  test the programm in other computer, the same problem
computer1: installed vs 2012, 64bit win8 ,naviswork2015,(navsiwork install the default path)
computer2: installed vs 2012, 32win7 ,naviswork2014,(navsiwork change the install path ,not the  default path)
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
namespace TimerLinerTest
public partial class Form1 : Form
public Form1()
InitializeComponent();
private void button1_Click(object sender, EventArgs e)
try
string FileName = "C:\\Users\\summe_000\\Desktop\\pj-dmL(located).nwd";
documentControl1.Document.TryOpenFile(FileName);
DataTable dt = new DataTable();
int i = 0;
DocumentTimeliner doc_timeliner = documentControl1.Document.GetTimeliner();
foreach (TimelinerTask task in doc_timeliner.Tasks)
dt.Rows[i][0] = task.ActualStartDate.ToString();
dt.Rows[i][1] = task.ActualEndDate.ToString();
dt.Rows[i][2] = task.PlannedStartDate.ToString();
dt.Rows[i][3] = task.PlannedEndDate.ToString();
dt.Rows[i][4] = task.DisplayName;
dt.Rows[i][5] = task.TaskStatus.ToString();
dt.Rows[i][6] = task.ProgressPercent.ToString();
dt.Rows[i][7] = task.Children[0].DisplayName;
i++;
dataGridView1.DataSource = dt;
catch (Exception ex)
MessageBox.Show(ex.Message);
Tags (1)
3 REPLIES 3
xiaodong_liang
in reply to: suzipeng
the reason is, Timeliner and ClashTest have not been exposed to .NET control application. Sorry if this is a bad news to you. You can access them by plugin.
zjf3295286
in reply to: xiaodong_liang
can we run TimelinerTask in the plugin
xiaodong_liang
in reply to: zjf3295286
Rail Community
