Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Sweep Geometry with NWCreate API
9 REPLIES 9
Message 1 of 10
916 Views, 9 Replies
Greetings,
I have developed a loader using the NWCreate API, but now I'm stuck.
As input I have polygon contours (profiles), which I need to extrude or rotate to make solids in NavisWorks.
Input for translational sweeps: Sweep length, sweep direction(vector), coefficients of sweep plane, polygon contour
Output: Polygon contour is extruded in space to form a solid.
Input for rotational sweeps: Sweep axis, sweep rotation angle, coefficients of sweep plane, polygon contour
Output: Polygon contour is rotated in space to form a solid
How can I accomplish this using the NWCreate API?
9 REPLIES 9
Message 2 of 10
xiaodong_liang
some comments from our engineer team:
two options.
  1. Just do it yourself. For a translational sweep, you can just construct polygons for the edges of the sweep. For rotational sweeps, you can use the Conic function to create the curved surfaces. This would be probably the most reliable method.
  2. You could use the B-Rep functions to create a Prism or a Revolve. You would construct a Face that represents the profile to sweep, then pass it to one of the two functions. The B-Rep APIs may be a bit harder to use. I would probably recommend the first option unless the profiles are very complicated. But if they are planar with linear edges, then it should be straightforward. If the profiles they want to extrude have curved edges, and the want to revolve it, the it’s a bit harder. The B-Rep API might be a better option.
Hope this helps.
Message 3 of 10
in reply to: xiaodong_liang
I saw elsewhere in the Autodesk forums (http://forums.autodesk.com/t5/Navisworks-General-Discussion/nwcreate-and-BRep-objects/td-p/2706251) that the B-Rep modeling functionality is not available with the stand-alone version of NWCreate.  This post if from 2009, though.  Is this still the case?
Message 4 of 10
xiaodong_liang
yes, the current version has still no API for B-Rep. Sorry if this a bad news for you.
Message 5 of 10
I am attempting to extrude a b-spline over a specific distance to create the side of a component. I have successfully created the b-spline, but when I attempt to extrude it with the following, I cannot set the extrusion distance - Navisworks defaults to 20 meters.  What am I missing?
LcNwcExtrudedSurface Surface(curve, new LtVector{ 0,0,1 }); //20 meters - can't fight
LcNwcFace face(Surface, LI_NWC_SENSE_NEGATIVE);
LcNwcShell shell;
shell.AddFace(face);
Nwstream.BRepShell(shell)
Message 6 of 10
xiaodong_liang
could you share a sample project that can demo this issue? I can test at my side to diagnose. Thank you.
Message 7 of 10
Xiaodong -
A sample project is attached.  The b-spline projection starts on line 60 of BSplineLoader.cpp.  Thank you for your help.
Gordon
Message 8 of 10
Xiaodong -
I should have mentioned: this sample project results in a file loader that takes .bsp files (I made up the file extension). Just create a text file and give it a .bsp extension and use that - this sample project doesn't really read the .bsp file at all.
Please let me know if you have any questions.
Gordon
Message 9 of 10
xiaodong_liang
Hi Gordon,
I failed to build your project, but I also consulted with our engineer in the mean time. He shared a quick comment:
The problem here is that they are creating just a surface. In this case, an “extruded surface” is a semi-infinite surface that needs to be bounded before it can be correctly rendered.
It sounds like what they want to do is use the Prism function instead, LiNwcBRepCreatePrism, which takes an entity (either a loop or a face), and extrudes it in a given direction for a specified distance.
I think maybe these comments can help you already.
I will also find time to make your project working at my side. I believe I simply missed something.
Message 10 of 10
Xiaodong -
That makes sense.  I am able to create a B-Spline Curve (LcNwcBSplineCurve).  Can you briefly explain how I can get from a Curve to a Loop or a Face?  I can't figure it out from the documentation and I don't see any examples in the API that demonstrate this.
Thank you.
Gordon
Rail Community
