I need to add tags using API C# similar to the attached screenshot. As far as I know, it's not possible to add tags via API, if so how can I simulate this functionality? Is it possible to do so using RedlineLine and Redline
@alexandrescoelho
Hello Alexandre,
I see you've given valuable support for Navisworsk API to people here in the forum. Can you check please this requirement if you can help?
Thank you!
