Navisworks API
Navisworks API
Active Member
x2dalyon
Message 1 of 5 (248 Views)
Simulate 2012 .NET API - Can I append a file and exclude references?
248 Views, 4 Replies
01-04-2012 01:36 PM
It seems that many of the DWG files I am appending into a composite model reference each other.  I would like to ignore the X-REFs when appending the file.  Is there a way to do that?
Active Member
x2dalyon
Message 2 of 5 (237 Views)
Re: Simulate 2012 .NET API - Can I append a file and exclude references?
01-06-2012 05:59 AM in reply to: x2dalyon
If I can not exclude them on the append, can I remove the layers from the external references once appended?  I created a search like this:
items = Autodesk.Navisworks.Api.
Application.ActiveDocument.Models.GetRootItems().DescendantsAndSelf.Where(x => x.IsLayer && (x.DisplayName.Contains("|")));
I am unsure of the .NET or COM syntax to remove the layers and their contents from this point.
KempCE
Message 3 of 5 (235 Views)
01-06-2012 08:13 AM in reply to: x2dalyon
Has any thought been given to creating a pre process script that will remove all x-refs from the dwg?
I am quite sure you can remove all Xref's thru an AutoLisp routine.  You could even compose\download a utility that would Generate The Script Then execute script.
Colin
Active Member
x2dalyon
Message 4 of 5 (231 Views)
01-06-2012 09:08 AM in reply to: KempCE
Thank you for the sugestion. I think it woud be more effecient to be able to set the File Reader option that you find in global options which allows you to turn off X-REFS.  Or importing a Global Options file that has that option specified.  I have not been able to find how to do either of these in the COM help or the API help.
Active Contributor
deanlyon
Message 5 of 5 (163 Views)
06-25-2012 07:03 AM in reply to: x2dalyon
The only way I know of to do this is to manually set the Global Options.  In Options go to File Readers, then DWG/DXF then Uncheck Convert XRefs.  If someone has a suggestion as to how to do this with the API. I am eager to hear it as well.
