Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Simulate 2012 api not setting color.
4 REPLIES 4
deanlyon
613 Views, 4 Replies
I have been using the api to set overrides for a while now. The transparency and hide functions work for me. However the color seems to only override with White.  I have now had a request to override with a color they can set in the progam.  Please look at the code below and see if I am implementing it incorrectly.
void SetFileColor(string sFile, double red, double green, double blue)
Color color = new Color(red, green, blue);
string pattern = "^" + Regex.Escape(sFile.ToLower()).Replace(@"\*", ".*").Replace(@"\?", ".") + "$";
Regex exp = new Regex(pattern);
IEnumerable<ModelItem> items = Autodesk.Navisworks.Api.Application.ActiveDocument.Models.GetRootItems().
DescendantsAndSelf.Where(x => exp.IsMatch(x.DisplayName.ToLower()));
Autodesk.Navisworks.Api.Application.ActiveDocument.Models.OverridePermanentColor(items, color);
4 REPLIES 4
xiaodong_liang
in reply to: deanlyon
the color value is in the range of 0 ~ 1. I guess you set the values like 255, 255,0
Hope it is the case.
deanlyon
in reply to: xiaodong_liang
I am passing a color of 0,170,170 for a Teal color, and it still renders white.
ulski1
hi,
you need to use r g b code divided by 255
colorVec.Data1 = Rcol/colorfactor
 colorVec.Data2 = Gcol/colorfactor
 colorVec.Data3 = Bcol/colorfactor
where colorfactor =255
Ulrik
deanlyon
in reply to: ulski1
Thank you. I now found in the help where Color Property says that the value is between 0 and 1.
Rail Community
