Hi
Is there anyway of programmatically rendering the image to a file using the API, .NET or COM?
Ideally I would like to be able to select the format (jpeg), renderer (Presenter) and Size (Explicit).
I guess it would be possible to use the DrawToBitmap method of the ViewControl but this would only allow the use of the viewport renderer, is this correct?
Many Thanks
Simon
I do not think we have implemented DrawToBitmap which overrides from Windows .NET control.
But probably the COM API could help you, which could be called by .NET.
<2012>\api\COM\examples\ACTX_03
<2012>\api\COM\examples\ACTX_07
<2013>\api\COM\examples\ActiveX\ActiveXSnapshotExample
<2013>\api\COM\examples\Auto\AutoPresenterExample
