Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Project units
7 REPLIES 7
Message 1 of 8
SergeyShevtsov
1659 Views, 7 Replies
Project units
Hello!
I want to merge my dxf file with navis drawing:
Autodesk.Navisworks.Api.Document doc = Autodesk.Navisworks.Api.Application.ActiveDocument;
                    if (doc.TryMergeFile(@"C:\test1.dxf"))
                        MessageBox.Show("Merge successful.");
 But when i merge this files.I open Tree Structure. Navis project has units "Inches", but test1.dxf has milimetres.
How can i set inches?
7 REPLIES 7
Message 2 of 8
Using the .NET API, we can get the value of the Units for a document using the Document.Units() property. But it returns the units of the first model only. And setting the value is not possible since this property is read-only.
Using the COM API does not either help since the part.LinearUnits (where part is InwOaPartition2) is read-only and does not allow us to set the units.
We have had wish to provide the API to set units.
Message 3 of 8
Thx for answer! I found the way to set units without API and COM, but with external application. But for launnch this application i need use external C# reference. I am add this dll in a references. But when i try use some procedures or functions in my plugin Naviworks crash with fatal error.. I tryed to connect other dll (maybe those dll has any errors) wich i wrote by myself, wich show message only.. and the same result Nws was crashed. Is there the way to use external reference?
Message 4 of 8
The external reference of Navisworks plugin must be put within  <Navisworks installation path>\Dependencies\.
I am interested in how you set the unit 🙂 Did you get the handle of the dialog and swtich to the control of the Unit, and mimic changing unit? Is it possible to share some hints? Thank you!
Message 5 of 8
thanks for answer.
well for set units i used some scripts and windows handler. i think its wrong. but...
first of all i get screen size,then automaticaly press "structure view"  button, this button i check by coordinates,
after i try to find this window, then press other button etc
well i know that awful desition, but it works.
Best Regards,
Sergey
Message 6 of 8
JohnHon
in reply to: xiaodong_liang
Hi all,
Is there any updates on setting unit in api?
John
Message 7 of 8
xiaodong_liang
in reply to: JohnHon
Hi John,
This is still a wish
#11542: Ability to set the units of a document using .NET API.
I did not hear an update on this. Sorry if this is bad news for you.
Message 8 of 8
JohnHon
Hi Xiaodong.
Sad to hear this news.
How about using Naviswork to change the unit of the model?Is it possible?
John
Rail Community
