hi,i need to access nwd file views(name is right?),it's be called project brower in navisworks app. i have know how to get document savedviews. i find it with navisworks sdk example:nwsControl.APIState.SavedViews() . it's wok well to get current view points. but my nwd file have more views。i have no idear to get others view and view point? somebody help me?
by the way,i used com api,not .net api. becase my project need work in web brower. tks
Solved by xiaodong_liang. Go to Solution.
If you are talking about saved views then you may want to check they are not inside saved view folders first.
You will probably have to write code to traverse the folder structure. This is from a COM API perspective, I can't comment on the .NET one.
hi,i kown how about to get savedviews .i wan't to get drawing,view and other's emlement,all of this include of "project brower" in the navisworks app.please see my print screen.thank you.
