I am doing naviswork automation through .NET.
I place a rectangle and rotate a rectangle to 30degree, the rotation towards Z Axis(0,0,0) and trying to scale towards X-Axis, the scale is not coming properly and shape of the object is getting change.
Following is my transformation matrix.
Rotation = {0.866025, 0.5, 0, 0, -.5, 0.866025, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1}.
Scale = {2, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1}
Rotation is working fine.
i used to multiple Rotation * Scale
My result is {1.73205, 0.5, 0, 0, -1, 0.866025, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1}
then i set this matrix to transform(eObjectType_nwLTransform3f) matrix.
Is there any other way to do scale a rotated object also please tell me.
I am very new to Naviswork as well as 3D.
Please help me.
I assume you are using COM API to transform the object, instead of the new API of .NET in 2014. I created a rectangle in a DWG and gave it a test with the following code. It firstly rotates and next scales. To make clearer, I spilt it to the two steps. The attachment is the DWG and the snapshots at my side. The result looks well to me.
If you are still having problem, please do isolate and provide more details, particually the code demo.
public override int Execute(params string[] parameters) { Document oDoc = Autodesk.Navisworks.Api.Application.ActiveDocument; ModelItemCollection oMC = oDoc.CurrentSelection.SelectedItems; ComApi.InwOpState10 oState =ComApiBridge.ComApiBridge.State; ComApi.InwOpSelection oSel = ComApiBridge.ComApiBridge.ToInwOpSelection(oMC); // create transform matrix ComApi.InwLTransform3f3 oTrans1 = (ComApi.InwLTransform3f3)oState.ObjectFactory (ComApi.nwEObjectType.eObjectType_nwLTransform3f, null, null); // make rotation ComApi.InwLRotation3f2 oRot = (ComApi.InwLRotation3f2)oState.ObjectFactory (ComApi.nwEObjectType.eObjectType_nwLRotation3f, null, null); ComApi.InwLUnitVec3f oVec = (ComApi.InwLUnitVec3f)oState.ObjectFactory (ComApi.nwEObjectType.eObjectType_nwLUnitVec3f, null, null); oVec.SetValue(0, 0, 1); oRot.SetValue(oVec,45); oTrans1.MakeRotation(oRot); // transform oState.OverrideTransform(oSel, oTrans1); ComApi.InwLTransform3f3 oTrans2 = (ComApi.InwLTransform3f3)oState.ObjectFactory (ComApi.nwEObjectType.eObjectType_nwLTransform3f, null, null); //make scale ComApi.InwLVec3f oScaleVec = (ComApi.InwLVec3f)oState.ObjectFactory (ComApi.nwEObjectType.eObjectType_nwLVec3f, null, null); oScaleVec.SetValue(2, 1, 1); oTrans2.MakeScale(oScaleVec); // transform oState.OverrideTransform(oSel, oTrans2); }
Thanks for your reply. I am using COM API and Navisworks 2012. I used to multiply both the matrix(Rotation and Scale) to get solution, its working well.
Once again Thank you so much.
