Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
pdms properties
6 REPLIES 6
Evgueny
1229 Views, 6 Replies
pdms properties
Hello. I need to use pdms properties in my plugin. I want to take any unique ID from it. Can you help me with it?
Regards. Evgueny.
6 REPLIES 6
Evgueny
in reply to: Evgueny
how can i get pdms properties?
ulski1
hi Evgueny,
PDMS properties are in the lcldrvm_props category and the properties can be accessed directly via "lcldrvm_prop_myprop" where you replace "myprop" with what ever property you are after.
Example a search for the pdms uda "discipline" with wildcard:
searchObject.SearchConditions.Add(SearchCondition.HasPropertyByName("lcldrvm_props", "lcldrvm_prop_discipline").DisplayStringWildcard("*Pip*").IgnoreStringValueCase().StartGroup());
Example a seach for the pdms uda "myprop" without wildcard:
searchObject.SearchConditions.Add(SearchCondition.HasPropertyByName("lcldrvm_props", "lcldrvm_prop_myprop").EqualValue(VariantData.FromDisplayString("testvalue")).IgnoreStringValueCase().StartGroup());
regards
Ulrik
xiaodong_liang
Hi Evgueny,
Could you check if the comments ulski shared has answered your question? Please mark it as a solution it helps. Thank you!
Evgueny
in reply to: xiaodong_liang
with search object I could not work. "FindAll" method to produce an error.
But ulski gave me directions. And now i'm using:
PropertyCategories.FindPropertyByDisplayName("PDMS","USERM").Value.ToString())
Evgueny
Thanks very much!
chiris.c
this is function i  use in my project.  use it to load  modeitem PDMS  properties
input propertiesname you want search  such as "Name "   "Hbore" "Type"
----------------------------HOW TO USE------------------------------------------------
chaxunPDMSshuxing("Name", modelitem).Replace("DisplayString:", ""));
chaxunPDMSshuxing("Hbore", modelitem).Replace("Int32:", ""));
--------------------------------------------FUNCTION-----------------------------------------
public static string PDMSproperties(string propertiesname, ModelItem modelitem)
string a = "";
if (modelitem != null && modelitem.PropertyCategories.FindCategoryByDisplayName("PDMS") != null)
PropertyCategory pcat = modelitem.PropertyCategories.FindCategoryByDisplayName("PDMS");
if (pcat != null)
DataProperty PDMSpro = pcat.Properties.FindPropertyByDisplayName(shuxingming);
if (PDMSpro != null)
string s = PDMSpro.Name.ToString();
if (PDMSpro.Value.ToString() == "")
return s;
else
return PDMSpro.Value.ToString();
else
return a;
else
return a;
else
return a;
Rail Community
