Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Output of objects with (select) properties to XML file?
1 REPLY 1
henrikljungberg5467
406 Views, 1 Reply
How would it be possible to output a selection of objects (maybe contained in a search set or selection set) to a custom XML file?
We would also want to output the objects properties and attributes to the xml. Does anybody have an example how this could be achieved?
Best regards,
Henrik Ljungberg
Tags (1)
1 REPLY 1
hi,
What I know is to export the XML by UI and get to know the format. Then write the XML yourself according to such format. I do not see a direct way with current API.
Rail Community
