I am using Navisworks review 2010 , using the API when I use .OverrideColor method to change the color for a selection , the color does change but the rendering is falt, there is no shading or anything.
If you user the OverrideColor command from User interface in Navisworks review then rendering is ok.
You can easily reproduce the problem by using delivered sample api\COM\examples\AUTO_02
So my question is it a known issue and what is the fix for it.
firstly, 2010 is not in our support list anymore. Can you also see such issue in 2011 and above? Could you share a screenshot to help to explain a bit? sorry frankly I have not quite understood what the scenario is.
Refer to the attached document to see the problem that I am referring to. If you need any further information let me know.
thanks
ali
Yes, same problem occurs in 2011 also. I did attach the screen shot and am attaching it again now incase you didnt get it earlier.
looks like add attachment link is not working. Any other way to attach a file
thanks
