Hi all, help please.
I am developing a Navisworks plugin which needs data from a Mysql database using C# and .Net API. The connection works fine outside the plugin, but doesn't work in the plugin. After some tests, I find that the plugin can not use classes outside the project which the plugin in, which also explain why the plugin can not use the link classes needed to connect Mysql. But how can this work?
I'm so confused and waiting for help.
