Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Navis works Object ID via API
4 REPLIES 4
MCameron3d
3302 Views, 4 Replies
I am unsure, although is there a potential way to get each object unique refernece ID that is in navisworks to via the API?
E.g I have 3 objects called "Door", I would like to be able to tell the difference from each object.
Cheers,
Marc C
Tags (3)
4 REPLIES 4
Khez
in reply to: MCameron3d
Objects have certain categories of properties assigned by default in Navisworks, accessible via the properties panel (Shift+F7).
If you look in the Item tab of the properties panel, there's a property called "GUID", witch is a unique identifier.
Now properties only show in the panel when you have stuff selected, but you can  totally find an item programatically (via the search method), store it in a ModelItem type and get the guid property.
this is what you would do for a selected item:
Document oDoc = Autodesk.Navisworks.Api.Application.ActiveDocument;
//get only the first selected object
ModelItem oSelectedItem = oDoc.CurrentSelection.SelectedItems.ElementAt<ModelItem>(0);
//search for a specific data property(GUID) in a specific property category(Item)
DataProperty elemProp = oSelectedItem.PropertyCategories.FindPropertyByDisplayName("Item","GUID");
// Getting the value it is a variantData type of value, so I convert to displaystring before using ToString(), otherwise it will get something like this : "DisplayString:**********"
string elemGUID = elemProp.Value.ToDisplayString().ToString();
That was just for the GUID, but if you want to learn more about  properties, I suggest Reading this arcticle: Navisworks .NET API Properties
MCameron3d
in reply to: Khez
Hi Khez,
fantastic answer, thank you. I am just a little unsure were you are refering to GUID. I do not seem to have that property available to see? I may be-able to capture it programitcally, this is I have yet to test.
These are the properties I get when I select an item.
I do see a handle within the "Entity Handle" tab although I am not sure this is what you are referring to, could you offer any more information incase I am missing a property option to display this?
Cheers,
Marc
xiaodong_liang
Hi Marc,
The file from different CAD format would have different attribute to identify the entity. Entity Handle is for DWG file. It can be used to identify the object.
http://adndevblog.typepad.com/aec/2012/06/persistent-item-id-of-navisworks-objects.html
Khez
Yeah, sorry, I'm only working with dwfx files, so I didn't know other type of files don't have a GUID.
Rail Community
