Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
modelItem select changed
1 REPLY 1
zmj122112
870 Views, 1 Reply
    I'm a fresh man at Navisworks API. Now I have a question , that is how can I create the messagebox when modelItem select changed?
   For example: If user select an object, winform shows the messagebox about it's property. When user change another object selected ,winform shows the messagebox again.
Thanks!
1 REPLY 1
xiaodong_liang
in reply to: zmj122112
you just need to delegate the event:  DocumentCurrentSelection.Changed, when the event fires, get current selection, and access its properties to display in your dialog or panel.
Rail Community
