I'm a fresh man at Navisworks API. Now I have a question , that is how can I create the messagebox when modelItem select changed?
For example: If user select an object, winform shows the messagebox about it's property. When user change another object selected ,winform shows the messagebox again.
Thanks!
Solved by xiaodong_liang. Go to Solution.
you just need to delegate the event: DocumentCurrentSelection.Changed, when the event fires, get current selection, and access its properties to display in your dialog or panel.
