Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Merging viewpoints
1 REPLY 1
evesi
509 Views, 1 Reply
Merging viewpoints
If I have two seperate distinct nwf's which both contain/refer the same content (being a single nwd) but have different viewpoints stored, is there a way to merge the viewpoints within these nwf's while retaining both the hide/required attributes and appearance overrides?
Could this be done in theory? Ideally I'd like to implement this through .net api
Tnx.
1 REPLY 1
Khez
in reply to: evesi
It is totally possible.
This 1 2 3 parts tutorial is really helpfull for working with Viewpoints
In your case(this is Csharp, but the method is similar in VB):
You need to first make a copy of the active document's currentViewPoint:
(in the first document)
public void CopyViewPoint()
public Viewpoint oCurVP;
oCurVP = Autodesk.Navisworks.Api.Application.ActiveDocument.CurrentViewpoint;
public Viewpoint oCopyVP; oCopyVP = oCurVP.CreateCopy();
 Then switch to the other document, and tell the api that you want that copy as the new viewpoint.
public void ApplyViewpoint()
Autodesk.Navisworks.Api.Application.ActiveDocument.CurrentViewpoint.CopyFrom(oCopyVP); }
 You might want to store the copy in in a property more than a variable if it doesn't work.
What it should do is apply the same camera position,rotation, zoom to the second document. It doesn't not affect what is hidden/selected, only camera properties.
Rail Community
