I have 2 models that don't have the same origin. I have placed an origin object in each model. Is it possible to get the location of both object and move them to the same place through the api?
Kind regards,
Sander
Solved by xiaodong_liang. Go to Solution.
hi, when I want to measure distance between 2models, I want to use the lock feature to maitain the direction through the api,which method should I used.
