Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
materials not applied
6 REPLIES 6
528 Views, 6 Replies
hello,
i don't understand why the material doesnt applied,
here is my code:
Dim state As Autodesk.Navisworks.Api.Interop.ComApi.InwOpState10
state = Autodesk.Navisworks.Api.ComApi.ComApiBridge.State
Dim PresenterPlugin As Autodesk.Navisworks.Api.Interop.ComApi.InwOwPresenterElement = Nothing
 Dim plugin
 For Each plugin In state.Plugins
   If plugin.ObjectName = "nwOwPresenterElement" Then
         PresenterPlugin = plugin
      MsgBox(PresenterPlugin.ToString, MsgBoxStyle.OkOnly," Presenter Plugin OK")
          Exit For
   Else
      MsgBox(" Presenter Plugin non  détecté")
Next
 PresenterPlugin.UserMaterials.AddFromArchive("Aluminium poli")
 If state.CurrentSelection.Paths().Count > 0 Then
      For Each path As InwOaPath In state.CurrentSelection.Paths()
      PresenterPlugin.MaterialMappings().AddMapping("Aluminium poli", path, True)
      Next
 Else
       MsgBox("la selection est vide")
 the presenter plugin is detected and the material is added to the UserMaterial list
but the material is not applied to the currentSelection
and there is no Error Msg.
do i miss something?
thanks for help
vanessa
6 REPLIES 6
xiaodong_liang
My questions:
- is this a Control based application, or a plugin?
- does this issue happen with any model or specific model?
- does hit issue occur with any material or specific one?
in reply to: xiaodong_liang
hi, thanks for your help
so, this is a Plugin,
and this morning i have tried differents materials and differents models, it still doesn't apply
i understand plugin  Presenter works only with Com APi, but i suppose i can work with it if i use APIBridge in .NET?
i really don't understand where is the problem !
xiaodong_liang
sorry I was not able to get back soon.
The blog below is what I wrote on presenter. It can still work. Note: from Navisworks 2015, Presenter and the relevan API are removed.
http://adndevblog.typepad.com/aec/2013/12/working-with-presenter-by-api.html
Could you check the blog if it helps you to figure out your problem?
hi, yes i have already read this blog, it help me to write the code you can see in my first post as i say in the precedent post, the plugin Presenter is found and the material is added in the palette but not applied on my model. i don't undestand why. i use this code in a addinPluggin and i use Navisworks simulate 2013 where is the problem? thanks vanessa
xiaodong_liang
are you still having the issue? If yes, could you share a demo code project and the model file? I doubt the object has been overridden with other rendering..
Unfortuately this Question is still unanswered.
I'm trying to change some materials and got stuck.
Can you please provide the demo code for me?
I am working with .Net Studio with the ComApiBridge and Navisworks 2014
Thanks!
Andreas
Rail Community
