Navisworks API
Navisworks API
Distinguished Contributor
bthatcher
Message 1 of 4 (209 Views)
Limit selection to specific objects
209 Views, 3 Replies
01-22-2013 11:59 AM
I would like to limit the selection to spicific objects. A portion of the model is transparent and I would like to be able to select objects through the transparent objects. Is that posible? Thanks.
ADN Support Specialist
xiaodong.liang
Message 2 of 4 (202 Views)
Re: Limit selection to specific objects
01-23-2013 05:58 PM in reply to: bthatcher
I'd suggest you take a look at Find API of Navisworks. here is one post which you could get started with.
http://adndevblog.typepad.com/aec/2012/05/navisworks-net-api-find-item.html
e.g. for your question, one way could be:
   Document oDoc =
               Autodesk.Navisworks.Api.Application.ActiveDocument;
           IEnumerable<ModelItem> items =
                   from x in oDoc.Models[1].RootItem.
                       DescendantsAndSelf
                   where x.HasGeometry && x.Geometry.ActiveTransparency >0
                   select x;
           // highlight the items
           oDoc.CurrentSelection.CopyFrom(items);
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
bthatcher
Message 3 of 4 (187 Views)
01-31-2013 11:53 AM in reply to: xiaodong.liang
I'm not sure I've explained myself clearly. I have a model with several modelItemCollections. Some of the modelItems are have a 95% transparency, the rest no transparency. I want to select on the screen but only be able to pick the non-transparent modelItems. They are part of thier own modelItemCollection. So in the attached image, if the user clicked where the red arrow is, they woukd get the cyan modelItem, even though that modelItem is behind the transparent modelItem denoted with the red boundry. Thanks.
xiaodong.liang
Message 4 of 4 (163 Views)
02-19-2013 02:36 AM in reply to: bthatcher
I see. you want to cusmomize the selection when user is selecting. Sorry, in current releases, the picking behavior cannot be customized. Even though you could get OnCurrentSelectionChanged(/Chaning), API does not allow you to change the selection in the events.
Xiaodong Liang
