Navisworks API
Navisworks API
New Member
0 Kudos
Post 1 of 2
Instantiate entities with Naviworks API
190 Views, 1 Replies
08-23-2012 07:40 AM
Is it possible to instantiate 3D models on a given position by scripting?
Say, I've got a MyModel.fbx file and I want to create lots of instances of this model in a scene each one with a position, a rotation and a scale. What possible ways could I do that? Would it be better to use .NET, COM or NwCreator?
Thanks in advance.
ADN Support Specialist
81 Kudos
Post 2 of 2
Re: Instantiate entities with Naviworks API
08-30-2012 02:51 AM in reply to: guilhermecosta_gca
firstly, NwCreate is the correct direction. NwCreate  provides two means:  either for export of NWD files from a third party application (LiNwcApi) or to implement a file loader (LiNwcLoader) for NavisWorks. So, the second one meets your requirement. It allows you load 3rd file format and convert the data to the models in Navisworks scene. The SDK \api\NwCreate provides samples and API documentation.  loader is a good sample.
Secondly, I have to emphasize: NwCreate produces the models in from a blank file, no matter LiNwcApi, LiNwcLoader. That is to say, you cannot create models in the existing file.
A practice is:  you could produce the files of your own models with NwCreate, and Append/Merge to the existing file.
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
