Hi all,
I am new to Navisworks api. I was able to run the net api examples and create some simple ones by myself. But I do not know how to debug the plugin. Is that possible? Or how can I debug my application?
Thanks in advance!
Anna
Solved by zhangle. Go to Solution.
Sorry but the website is being transferred and the links are all broken.
New address: http://lezhang.net/2013/11/12/how-to-debugrun-navisworks-2013-api-programs/
Hi there zhangle,
I read through your article, and it looks like what I need.
My only problem is I can't copy the files to any subfolders within C:\Program Files\ folder hierarchy with xcopy. It works no problem if I redirect it to C:\Test\ - but of course that defeats the purpose since we need it to get down to the Navisworks \Plugins folder
I have full admin rights on my workstation, I should be able to change some settings on the \Plugins folder to achive the Post-Build event command line debugging workflow, right?
Any suggestions here?
Thx!
Take ownership of the Plugins folder, this should do 😉
