I would like to hide the green Pivot point when using Orbit, because I'm making a video where I orbit around a virtual building and the green Pivot point that displays on screen when orbitting is distracting for the audience. How can I do this?
I'm using Navisworks Freedom 2015.
Thanks!
- Joerik
hi,
the pivot point is really a 3d object called SWpivotball.obj you could locate this file on your harddrive and try to replace it with an empty obj file with same name. I have not tried this - but I might work
Ulrik
Great suggestion, thanks. I tried looking for the file before but couldn't find it, but this seems to be the right one!
However, putting an empty 'SWpivotball.obj' file in there doesn't remove the pivot 3D animation :(. I tried the same with 'SWpivotballhide.obj', but the pivot point remains.
Any other ideas? 🙂
Thanks!
