Navisworks API
karteek.iitm
Message 1 of 12 (321 Views)
Hide model items
321 Views, 11 Replies
01-10-2013 10:45 PM
I am trying to read selection items for tasks in timeliner and trying to hide them using API.
this is the code for the same.
foreach (Tl.TimelinerTask oTask in tl_doc.Tasks)
      DateTime date2 = oTask.ActualStartDate.Value.Date;
      int result = DateTime.Compare(date1, date2);
      if (result > 0 || result == 0)
          Tl.TimelinerSelection oTlSel = oTask.Selection;
         if (oTlSel != null)
                         if (oTlSel.HasExplicitSelection)
                                     Nw.ModelItemCollection oExplicitSel = oTlSel.ExplicitSelection;
                                   Autodesk.Navisworks.Api.Application.ActiveDocument.Models.SetHidden(oExplicitSel, false);
But when i debug the program it says "the name 'oExplicitSele' does not exist in the current context. Can anyone please explain how to hide selection items attached to a task.
ADN Support Specialist
xiaodong.liang
Message 2 of 12 (313 Views)
Re: Hide model items
01-10-2013 11:04 PM in reply to: karteek.iitm
It is C# and you are using oExplicitSel in the brackets,  right? I beleive you have figured it out after posting the question :smileyhappy:
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
karteek.iitm
Message 3 of 12 (305 Views)
01-11-2013 12:41 AM in reply to: xiaodong.liang
Thank you for your reply Mr. Xiaodong Liang.
When i run the code I am facing the following error (although i added the dll as a refrence in thr app). Can you please explain why this is happening.
System.IO.FileNotFoundException: Could not load file or assembly 'Autodesk.Navisworks.Timeliner.dll' or one of its dependencies. The specified module could not be found.
karteek.iitm
Message 4 of 12 (304 Views)
01-11-2013 12:42 AM in reply to: karteek.iitm
I have also added all the dependencies through .net reflector.
xiaodong.liang
Message 5 of 12 (294 Views)
01-13-2013 11:01 PM in reply to: karteek.iitm
Please take a look at this post. Hope you could find what you missed.
http://adndevblog.typepad.com/aec/2012/10/timeliner-api-part1.html
In addition, please switch the .NET framework to 4.0 if it helps.
Xiaodong Liang
karteek.iitm
Message 6 of 12 (284 Views)
01-18-2013 03:44 AM in reply to: xiaodong.liang
I developed my code based on the link which you have provided and did not miss anything.
.NET Framework 4.0 does not help too.
xiaodong.liang
Message 7 of 12 (268 Views)
01-21-2013 09:33 PM in reply to: karteek.iitm
So, I believe your app is a standalone EXE of .NET control. Unfortunately TimeLiner/ClashTest has not exposed to .NET control. you can only use them in a plugin.
The possible way I can think of is: you create an automation and plugin. plugin accesses timeliner and writes the info you need into a temporary file. When your app of .Net control wants to get timeliner info, it launches the automation, the automation starts a process of Navisworks (invisible), executes the plugin. finally, the app pf .Net control reads the temporary file and gets the info.
Xiaodong Liang
karteek.iitm
Message 8 of 12 (262 Views)
01-22-2013 04:51 AM in reply to: xiaodong.liang
That helps a lot. Thank you for the information.
Active Member
dickinsjohn
Message 9 of 12 (234 Views)
02-24-2013 11:22 AM in reply to: karteek.iitm
you havent included the .dll file in references. please find it in navisworks freedom folder. cheers.
xiaodong.liang
Message 10 of 12 (214 Views)
02-26-2013 05:01 PM in reply to: dickinsjohn
Hi dickinsjohn,
I am not sure which question you are answering. But please note: no API for Freedom.
Xiaodong Liang
