Navisworks API
New Member
talesfc
Message 1 of 4 (200 Views)
Help with DockPanePlugin
200 Views, 3 Replies
10-04-2012 12:20 PM
Hi
I am new to Navisworks API and would like help on using the DockPanePlugin. I have read the "DockPane Tutorial" by Le Zhang (http://lezhang.net/2012/06/13/navisworks-2013-api-dockpane-tutorial/) and tested the  DockPane Helloword example.
However I have not found pointers on how to access gui controls on the panel. For example, how can I set/get the text content on a textblock on the panel ?
regards
Tales
Employee
saikat
Message 2 of 4 (197 Views)
Re: Help with DockPanePlugin
10-04-2012 05:35 PM in reply to: talesfc
Hi Tales
Once you have GUI controls on the panel, you can access it in the same way you would have accessed a GUI located on a Windows Form from the class which initializes the Form. So the options are -
Making the GUI control's (say TextBox) modifier public and acessing it from the, say, BasicDockPanePlugin.cs class in the BasicDocPanePlugin SDK sample.
Or Passing the variable parameter to the Panel and using that to get/set the values of a TextBox - just like it has been done for the Label in the same SDK sample.
Hope this helps.
Saikat Bhattacharya
New Member
talesfc
Message 3 of 4 (185 Views)
10-06-2012 05:37 PM in reply to: saikat
Hi Saikat,
Thanks for helping. Following your advice I succeeded accessing the wpf control.
regards
Employee
saikat
Message 4 of 4 (176 Views)
10-07-2012 11:19 PM in reply to: talesfc
Thats great to hear, Tales. Thanks for letting me know.
regards
Saikat Bhattacharya
