Navisworks API
Navisworks API
New Member
jtaralson
Message 1 of 5 (408 Views)
Heads Up Display (XYZ Corrdinates)
408 Views, 4 Replies
06-11-2012 08:53 AM
This may be an easy one, but I am unable to find a way to turn the XYZ corrdinates off on the bottom left of the ActiveX control for NavisWorks.  I'm looking to export images from a model, to put into a report.  I can export the image and resize it correctly, but the XYZ corrdinates from the control remain the same size and only show half the Corrdinates within the image.
Is there an easy way to hide these corrdinates within the ActiveX control, that I may be missing.  I've dug through the control with no luck so far.
Thanks.
ADN Support Specialist
xiaodong.liang
Message 2 of 5 (354 Views)
Re: Heads Up Display (XYZ Corrdinates)
08-20-2012 01:02 AM in reply to: jtaralson
I think you can turn it off just by changing registry settings, but you’ll need to make sure the ActiveX control isn’t running when you do it.
e.g. with NW2013 Redistributable control.
show_position = 0
xyz_triad = 0
in  HKEY_CURRENT_USER\Software\Autodesk\Navisworks ActiveX Redistributable\10.0\GlobalOptions\interface\display\hud
the icons will not appear.
show_position = 3 1
xyz_triad = 3 1
Note, there is a space in between “3” and “1”
The icons will appear.
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
Valued Contributor
JohnHon
Message 3 of 5 (219 Views)
09-18-2013 11:03 PM in reply to: xiaodong.liang
Dear Xiaodong,
Is it possible to turn on the HUD in .Net Api?
John
xiaodong.liang
Message 4 of 5 (202 Views)
09-28-2013 08:17 PM in reply to: JohnHon
Dear John,
the API for HUD is still a wish. I do not see a way at this moment. Sorry if this is bad news for you.
But for .NET control, it looks to me the HUD is turned on by default.
Xiaodong Liang
Valued Contributor
JohnHon
Message 5 of 5 (194 Views)
10-01-2013 11:00 PM in reply to: xiaodong.liang
Dear XiaoDong,
Thanks for your reply.
It is really a bad new for me.:smileysad:
Nevertheless, I can turn it on in Navisworks and the HUD will be dispalyed in .Net control.
Best Regards,
John
