Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Get global coordinates of the points of the triangle
2 REPLIES 2
1493 Views, 2 Replies
Help me please.
How to get the global coordinates of the points of the triangle?
using the class
class CallbackGeomListener : COMApi.InwSimplePrimitivesCB
		public void Line(COMApi.InwSimpleVertex v1,COMApi.InwSimpleVertex v2)
			// do your work
		public void Point(COMApi.InwSimpleVertex v1)
			// do your work
		public void SnapPoint(COMApi.InwSimpleVertex v1)
			// do your work
		public void Triangle(COMApi.InwSimpleVertex v1,COMApi.InwSimpleVertex v2,COMApi.InwSimpleVertex v3)
			Array array_v = (Array)(object)v1.coord;
			float x = (float)array_v.GetValue(1);
			float y = (float)array_v.GetValue(2);
			float z = (float)array_v.GetValue(3);
			ABasicPlugin.TriangleLIST.Add(x);
			ABasicPlugin.TriangleLIST.Add(y);
			ABasicPlugin.TriangleLIST.Add(z);
			array_v = (Array)(object)v2.coord;
			array_v = (Array)(object)v3.coord;
and function
ModelItemCollection oModelColl = Autodesk.Navisworks.Api.Application.ActiveDocument.CurrentSelection.SelectedItems;
COMApi.InwOpState oState = ComBridge.State;
COMApi.InwOpSelection oSel = ComBridge.ToInwOpSelection(oModelColl);
CallbackGeomListener callbkListener = new CallbackGeomListener();
foreach (COMApi.InwOaPath3 path in oSel.Paths())
	COMApi.InwLBox3f B3f = path.GetBoundingBox();
	// центральная точка примитива
	foreach (COMApi.InwOaFragment3 frag in path.Fragments())
		TriangleLIST = new ArrayList();
		frag.GenerateSimplePrimitives(COMApi.nwEVertexProperty.eNORMAL, callbkListener);
 I get the point of local.
2 REPLIES 2
An easy way of converting the local space (vertex positions) to world space (what you want) is to add the bounding box center of the geometry you're pulling vertex information from.
In your case, you already have the line here:
All you really need to do is loop over the triangles and add the points together :).
In my own implementation I use the C# API for this, item.Geometry.BoundingBox.Center. But I'm sure it can't be that hard to grab the Center XYZ values from a InwLBox3f.
xiaodong_liang
Hi Evgueny,
I have not tried what  johan.rensenbrink suggetsed, but the forum post I answered might be helpful
http://forums.autodesk.com/t5/Navisworks-API/Convert-LCS-to-WCS-with-COM-api/td-p/4840957
Rail Community
