Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Export to different file formats in the API
3 REPLIES 3
sanderobdeijn
984 Views, 3 Replies
Through the ui I can saveas
  • .nwf (2015)
  • .nwf (2014)
  • .nwf (2013)
  • .nwd (2015)
  • .nwd (2014)
  • .nwd (2013)
I can export to
  • 3d DWF
  • FBX
  • KML
And i can publish with extra options to NWD(2015)
If i look at the api I can only find.
Save to NWF. 2015/2014/2013
With the following command:
Application.ActiveDocument.SaveFile("FileName.nwf", DocumentFileVersion.Current);
and publishing to NWD 2015
PublishProperties properties = new PublishProperties();
Autodesk.Navisworks.Api.Application.ActiveDocument.PublishFile("FileName.nwd", properties);
Are the other options also exposed?
3 REPLIES 3
as far as I know, API has not exposed all abilities of product. exporting FBX is one wish which has been logged. sorry for this.
uros3d
in reply to: xiaodong_liang
So, there is no API exposed export options, but is it possible to extract for example, geometry and property information and make a custom exporter?
Also, when exporting to FBX only geometry and materials are exported, right? It seems to lose all element properties... Is it FBX format limitation or is it FBX exporter's fault?
xiaodong_liang
in reply to: uros3d
API allows you to get primitives of the geometries and the object's properties
http://adndevblog.typepad.com/aec/2012/05/get-primitive-from-solid-of-navisworks.html
http://adndevblog.typepad.com/aec/2012/05/navisworks-net-api-properties.html
As to the ability of FBX exporter, it is a kind of product question, sorry I have not an answer. I'd suggest you could post it on product board. Thanks for your understanding.
http://forums.autodesk.com/t5/Navisworks-General/bd-p/372
Rail Community
