Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Delete model
9 REPLIES 9
Message 1 of 10
bthatcher
890 Views, 9 Replies
Delete model
Is it posible to delete or remove an appended model? I cant find any obvious was through the .NET api. Thanks.
9 REPLIES 9
Message 2 of 10
xiaodong_liang
in reply to: bthatcher
Message 3 of 10
in reply to: xiaodong_liang
Whats the dumb down way to delete apended files in Navisworks. In 2013 I could right click delete? 2014 has no option to delete. I am in a Nwf file.
Message 4 of 10
xiaodong_liang
although this sounds like a product question, I checked Nw2014 quickly. It looks the [delete] is still avaiable there. is this what you are looking for?
Message 5 of 10
rtonin
hy all,
Is there another way to remove an appended model file without use Autodesk.Navisworks.Api.Interop.ComApi state.DeleteSelectedFiles() method?
this comAPI method not work properly on Naviswors 2022.
Rolando
Message 6 of 10
ulski1
in reply to: rtonin
What do you mean it doesn't work in Navisworks 2022? It never worked very well - did it get worse?
Message 7 of 10
rtonin
in reply to: ulski1
this is my mplementation method:
public void RemoveModelFromDocument(Autodesk.Navisworks.Api.Document doc, Autodesk.Navisworks.Api.Model modello)
if(modello != null)
try
doc.CurrentSelection.CopyFrom(modello.RootItem.AncestorsAndSelf);
Autodesk.Navisworks.Api.Interop.ComApi.InwOpState10 state =
ComApiBridge.State;
state.DeleteSelectedFiles();
catch (Exception e)
throw e;
when state.DeleteSelectedFiles() was called it raise an "Naviswork unknown error" exception. If I remove throw e; line model in not removed from document.
Rolando
Message 8 of 10
ulski1
in reply to: rtonin
I think the reason it doesn't work is you are parsing and object collection instead of a rootitem
try this change:
doc.CurrentSelection.CopyFrom(modello.RootItem);
Message 9 of 10
rtonin
in reply to: ulski1
In the above code I substitute selection with this line of code:
doc.CurrentSelection.CopyFrom(new List<ModelItem>() { model.RootItem });
but the same Exception is always raised.
In the meantime I have found a solution. I discovered that this exception is raised when the model I want to remove is the unique model in document's model list. Therefore I append a new model and after I can remove the old model and all work fine.
Thanks a lot for your suggestion.
Rolando
Rolando
Message 10 of 10
ulski1
in reply to: rtonin
You can never remove all models - Navisworks as a minimun need to hold one model
Rail Community
