Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Define Full Lights when generating NWD
2 REPLIES 2
pascal_guillas
661 Views, 2 Replies
we use Navisworks 2012.
We generate NWD files with FBX sources files using API, but when users open files, they have to select View -> Lighting -> "Full Light" for a correct exposed scene.
Is it possible to define this option with API code before saving NWD file ? or is there an option to set it by default in Navisworks 2012 ?
Pascal Guillas.
Tags (1)
2 REPLIES 2
ulski1
in reply to: pascal_guillas
hi,
in the .net API you need to link to the old com api (add ref. to the comapi dlls) after that you can use the following:
using
ComApi = Autodesk.Navisworks.Api.Interop.ComApi;
using
ComApiBridge = Autodesk.Navisworks.Api.ComApi;
//link to COM API
ComApi.InwOpState10 state;
state = ComApiBridge.ComApiBridge.State;
state.CurrentView.ViewPoint.Lighting = ComApi.nwELighting.eLighting_FULL_LIGHTING;
Ulrik
Thanks a lot !
It works fine.
Rail Community
