Hello
Is there ANY way to create Face Sets using the Navisworks API's?
What I am attempting to do: Import Storm Water Drains from a file into Navisworks
- Read a file that contains storm water drain (cylinder) data (geometry and properties). For each drain, create a FaceSet (essentially a cylinder) and apply properties (DataProperties) to that FaceSet (ModelItem).
If this is possible to do, can you please communicate which API I use.
My research has discovered that:
- The Automation API is not relevant to what I am doing. It is more for calling and automatically running existing plugins, open NW and auto-loading in projects and etc.
- The .NET API does not provide functionality to create ModelItems or edit ModelItem geometry.
- The COM API does not provide the ability to create nodes/model items/etc. It also does not allow you to edit an existing ModelItem's/Nodes/etc. geometry. All you can do is inspect existing elements and edit DataProperties such as colour, etc. So this API will not achieve our goals.
- The NWCreate API appears to achieve somewhat of our goals. It can, correct me if I am wrong, handle files with specific extensions and, I think, create elements/Nodes/ModelItems/??. This API is a C++ API, can this API also be used inside .NET C# like the COM API?
Knowing our goals, is what we are trying to do possible using the Navisworks API? Any response would be extremely helpful
