I admit this is a newbie question, but I can't seem to find the answer. I understand how to get access to the PLUGIN folders programs via registering them. But "how" do I run the other examples in the ACTX folders and the AUTO folders?
My Auto08.bat file reads:
C:\TEMP\AUTO_08.vbs ;;(yes, I copied AUTO_08.vbs into the TEMP folder)
"C:\TEMP\testing.nwc" ;;(yes, this NWC exists)
"C:\TEMP\duh.nwd"
"Title"
"password"
"11/04/2012"
When I run the bat file, first thing I get is the error msg:
When I OK the err msg box:
NW loads the NWC, but then nothing else happens
The error dialog means the line 46 of your code is problematic. Please check the logic of the code and if relevant lines before line 46 work well. Setting some msgbox to check the variables is one way I sometimes use to investigate VBS.
As I know, ‘subscript out of range’ is a common error which may occur for many kinds of reasons. Probably you could google with the keywords “subscript out of range” , or “ 800a0009”.
Or you would need to post a sample here to be diagnosed.
Thanks Xia: I admit, I was trying to use a routine provided by Adesk in the examples folder. I am not a programmer, so I am lost at debugging. Thanks for your help.
