Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Close Navisworks through API
3 REPLIES 3
sanderobdeijn
1423 Views, 3 Replies
I found that you can start navisworks with automation and start a plugin. Is it also possible to close Navisworks through the api.
3 REPLIES 3
you can just dispose the instance of the automation application. e.g. This below code is taken from the SDK sample api\NET\examples\Automation\CallExaminer
NavisworksApplication navisworksApplication = null;
try
// Start Navisworks
navisworksApplication = new NavisworksApplication();
//Call the Examiner Plugin using the arguments passed to this exe
navisworksApplication.ExecuteAddInPlugin("Examiner.Examiner.ADSK", args);
catch (InvalidOperationException e)
Console.WriteLine("InvalidOperationException: " + e.Message);
catch (ArgumentException e)
Console.WriteLine("ArgumentException: " + e.Message);
finally
//Close Navisworks
if (navisworksApplication != null)
navisworksApplication.Dispose();
Well I enabled the stayopen option in automation. The application should stay open most of the time. But sometime I would like to close it. But at this moment the automation instance is already disposed.
The StayOpen tells the Navisworks instance not to close even the application disposes the instance. I am afraid you have to find the process and kill it if you set this StayOpen.
Rail Community
