Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Clash property is null...? in Document class Help..
1 REPLY 1
371 Views, 1 Reply
Hi ,
When Debuging Clash test in example source as provided by autodesk, Clash property on the Document class is not generated Null value.
But Clash property on the Document class in my wpf project file is generated Null value.
same code, same way......same reference...
Why?? What's wrong?! please help..
1 REPLY 1
xiaodong_liang
so, you wanted to use Clash Test API in .NET control based app? Unfortunately, Clash Test is exposed in a plugin, while .NET control based app has not been able to access any plugin. Sorry if this is a bad news for you.
you may have to start an automation exe behind the control app. automation can call a custom plugin which accesses the Clash Test info.
Rail Community
