Dear all,
I am creating a window form application with document control and view control.
When I run following code, an exception occurs.
Autodesk.Navisworks.Api.Controls.ApplicationControl.Initialize()
RuntimeLoaderException
Cannot load suitable Navisworks runtime. Note that 32bit Navisworks Controls are not supported on 64bit OS except in DesignMode
For your information, I am using Visual Studio 10 and Navisworks Manage 2013.
Also, Autodesk.Navisworks.Controls.dll is added to the reference.
For Controls.dll,
Runtime Version:v4.0.30319
version:10.0.840.82
My PC is windows 7 Professional and both PC and Navisworks are 64- bit.
Could you help me to solve it?
John
Solved by xiaodong_liang. Go to Solution.
Dear Xiaodong,
Thanks for your answer. I change it to Any CPU and it works!
John
Hi, I have changed the Configuration Manager to "x86" and "Any CPU".
However, I still face the same error message.
Autodesk.Navisworks.Api.RuntimeLoaderException was unhandled HResult=-2146233079 Message=Cannot load suitable Navisworks runtime Source=Autodesk.Navisworks.Api StackTrace: at Autodesk.Navisworks.Internal.ApiImplementation.ApplicationImpl.InitialiseErrorHandling(ApplicationConfig config) at Autodesk.Navisworks.Internal.ApiImplementation.ApplicationImpl.InitialiseResources(ApplicationConfig config) at Autodesk.Navisworks.Internal.ApiImplementation.ApplicationImpl.InitialiseApi(ApplicationConfig config) at Autodesk.Navisworks.Api.Controls.ApplicationControl.InitializeImpl() at Autodesk.Navisworks.Api.Controls.ApplicationControl.Initialize() at Viewer.Program.Main() in C:\Working_Place_Joe\AMNIS\Technical Issue\Navisworks\Navisworks_2016_API_Training_Labs\Individual labs\Nw_Single_Doc_With_View\Program.cs:line 44 at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args) at System.AppDomain.nExecuteAssembly(RuntimeAssembly assembly, String[] args) at System.Runtime.Hosting.ManifestRunner.Run(Boolean checkAptModel) at System.Runtime.Hosting.ManifestRunner.ExecuteAsAssembly() at System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext, String[] activationCustomData) at System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext) at System.Activator.CreateInstance(ActivationContext activationContext) at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssemblyDebugInZone() at System.Threading.ThreadHelper.ThreadStart_Context(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart() InnerException:
Can you advise me what should I do?
Thank you.
