Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
always cannot find clash test plugin?
2 REPLIES 2
martinkaifa
499 Views, 2 Replies
why m_clash variable is always empty???????
No matter what file, the results are the same.
public void GetClashDetail() {
ComApi.InwOpState10 oState;
oState = ComApiBridge.ComApiBridge.State;
ComApi.InwOpClashElement m_clash = null;
foreach (ComApi.InwBase oPlugin in oState.Plugins())
if (oPlugin.ObjectName == "nwOpClashElement")
m_clash = (ComApi.InwOpClashElement)oPlugin;
break;
if (m_clash == null) //m_clash is always empty ??????
System.Windows.Forms.MessageBox.Show("cannot find clash test plugin!");
return;
ComApi.InwOclClashTest oNewTest = (ComApi.InwOclClashTest)oState.ObjectFactory(Autodesk.Navisworks.Api.Interop.ComApi.nwEObjectType.eObjectType_nwOclClashTest, null, null);
oNewTest.name = "Mytest";
oNewTest.status = Autodesk.Navisworks.Api.Interop.ComApi.nwEClashTestStatus.eClashTestStatus_NEW;
m_clash.Tests().Add(oNewTest);
Tags (2)
2 REPLIES 2
martinkaifa
in reply to: martinkaifa
I'm sorry,I should add that,it not a Plugin,it is a C# desktop program.
all the code:
using Autodesk.Navisworks.Api.Controls;
using ComApi = Autodesk.Navisworks.Api.Interop.ComApi;
using ComApiBridge = Autodesk.Navisworks.Api.ComApi;
using ComBridge = Autodesk.Navisworks.Api.ComApi.ComApiBridge;
using Autodesk.Navisworks.Api.Interop.ComApi;
using Autodesk.Navisworks.Api.Clash;
using Autodesk.Navisworks.Api.Automation;
using Autodesk.Navisworks.Api;
namespace NavisworksDemo
public partial class Form1 : Form
ViewControl VC;
DocumentControl DC;
public Form1()
InitializeComponent();
if (this.components == null)
this.components = new System.ComponentModel.Container();
VC = new ViewControl();
DC = new DocumentControl(this.components);
VC.DocumentControl = DC;
VC.Dock = DockStyle.Fill;
//VC.Location = new Point(Left + 10, Top - 10);
VC.Name = "myVC";
VC.Size = new System.Drawing.Size(750, 750);
this.Controls.Add(VC);
DC.SetAsMainDocument();
//open
private void tSMIOpenFile_Click(object sender, EventArgs e)
OpenFileDialog ofd = new OpenFileDialog();
if (ofd.ShowDialog() == DialogResult.OK)
DC.Document.TryOpenFile(ofd.FileName);
DC.Document.Tool.Value = Tool.Select;
//clash test event
private void tsmiClash_Click(object sender, EventArgs e)
Cla****erateResults();
void Cla****erateResults()
//find the clash detective plugin
if (oPlugin.ObjectName == "nwOpClashElement")//no find InwOpClashElement
break;
if (m_clash == null)//Always is null
return;
Hi martinkaifa,
.NET control based application cannot access Clash/Timeliner APIs. Sorry if this is a bad news for you.
If you want to get the clash info, you could workaround it by starting an automation behind the scene and invoke the relevant plugin which gets clash info, and transfer the data to your application. It is not elegant, but can help a bit.
Rail Community
