Navisworks API
Member
railrover
Message 1 of 3 (158 Views)
Adding New SavedViewpoint Problem
158 Views, 2 Replies
09-30-2012 06:11 PM
I am having a problem with the following code, which is failing beacuse it thinks Newvp is an unsupported type of SavedItem.
Dim Newvp AsNew Autodesk.Navisworks.Api.SavedViewpoint(doc.CurrentViewpoint)
Newvp.DisplayName = "Test"
doc.SavedViewpoints.AddCopy(Newvp)
How can this be, when I explicitly create Newvp as a SavedViewpoint?
Cheers
Mike
ssdiesel
Message 2 of 3 (153 Views)
Re: Adding New SavedViewpoint Problem
09-30-2012 07:32 PM in reply to: railrover
maybe you need to do smth like this:
Dim Newvp AsNewAutodesk.Navisworks.Api.SavedViewpoint(doc.CurrentViewpoint)
doc.SavedViewpoints.AddCopy(Newvp);
doc.SavedViewpoints.EditDisplayName(Newvp, "Test");
ADN Support Specialist
xiaodong.liang
Message 3 of 3 (129 Views)
10-10-2012 03:42 AM in reply to: railrover
please take a look at this blog if it helps.
http://adndevblog.typepad.com/aec/2012/06/navisworks-net-api-2013-new-feature-saved-viewpoint.html
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
