Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Adding Closest Grid Point Intersection to object in User Tab
6 REPLIES 6
2470 Views, 6 Replies
Hello everyone,
I'm using Navisworks 2014 and I'm trying to create a plugin to add to a specific/selected object the closest grid intersection point in a property user tab.
Although I know how to create the user tab and add properties pragmatically, I cannot find a reference to retrieve the closest grid intersection point. This should basically be what the clash detective "Grid Intersection" shows.
Should I use the "GridIntersection Class" to do this? And if so, where should I start?
Thanks!
6 REPLIES 6
xiaodong_liang
given a referenced point, you can use GridSystem.ClosestIntersection(point) to get the closest GridIntersection which tells the postion, level, line1 and line2 of the intersection.
I guess the referenced point of "Grid Intersection" in Clash Detective is ClashResult.Center.
In your case, you could use the BoundingBox center of the object you are interested in. or BoundingBox Max or Min.
in reply to: xiaodong_liang
Great! Thanks Xiaodong, I'll try it right now.
Xiaodong,
I'm having a hard time getting the intersection point data I can add to the user tab:
This is what I have:
static public Point3D GetClosestGridIntersection()
             //check that selection is valid
            if (!Autodesk.Navisworks.Api.Application.ActiveDocument.CurrentSelection.IsEmpty)
                //Get bounding box of the selection
                BoundingBox3D bb3d =
                   Autodesk.Navisworks.Api.Application.ActiveDocument.CurrentSelection.SelectedItems.BoundingBox();
                //get the closest grid intersection point
                GridIntersection oGridIntersection = Autodesk.Navisworks.Api.GridSystem.ClosestIntersection(bb3d.Center);
                //return the vector
                return oGridIntersection;
 I would then buidl the string I need to put in th euser tab property.
I get the following error message:
"Error 5 An object reference is required for the non-static field, method, or property 'Autodesk.Navisworks.Api.GridSystem.ClosestIntersection(Autodesk.Navisworks.Api.Point3D)'"
I'm new to C#... can someone let me know what I'm missing?
xiaodong_liang
The GridSystem class does not provide a static method to get the closest point. You need to get the current grid system and call ClosestIntersection. The following is the updated code:
          GridIntersection oGridIntersection = null; ;
              GridSystem oGS = Autodesk.Navisworks.Api.Application.ActiveDocument.Grids.ActiveSystem;
              oGridIntersection = oGS.ClosestIntersection(bb3d.Center);
          //return the vector
          return oGridIntersection.Position;
Thanks a lot!
Rail Community
