Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Add PropertyCategory and DataProperty with .NET using COM API
4 REPLIES 4
danielkazado
3795 Views, 4 Replies
     I am using Navisworks Manage 2014 and try to load new PropertyCategory and DataProperty to the selected items. I try to do it with a Plugin and Button4 in the Form shall load new PropertyCategory and DataProperty to the selected items.
     I get most of the information for the code from "http://adndevblog.typepad.com/aec/2012/08/addmodifyremove-custom-attribute-using-com-api.html"
     Find below my code for the button below, when I try to use it in Navisworks it gives error and close. Any advice ?
Private Sub Button4_Click(ByVal sender As Object, e As EventArgs) Handles Button4.Click
Dim nwState As Autodesk.Navisworks.Api.Interop.ComApi.InwOpState10
Dim nwPath As Autodesk.Navisworks.Api.Interop.ComApi.InwOaPath
Dim nwNode As Autodesk.Navisworks.Api.Interop.ComApi.InwGUIPropertyNode2                                    'PROPERTY CATEGORY
Dim nwProps As Autodesk.Navisworks.Api.Interop.ComApi.InwOaPropertyVec                                          'DATA PROPERTY LISTESI
Dim nwProps1 As Autodesk.Navisworks.Api.Interop.ComApi.InwOaProperty                                              'DATA PROPERTY
Dim nwDOC As Autodesk.Navisworks.Api.Document
nwDOC = Autodesk.Navisworks.Api.Application.ActiveDocument
Dim oItem As Autodesk.Navisworks.Api.ModelItem
For Each oItem In oDOC.CurrentSelection.SelectedItems
nwState = nwDOC.State
nwPath = nwState.CurrentSelection.Paths(1)
nwProps = nwState.ObjectFactory(Autodesk.Navisworks.Api.Interop.ComApi.nwEObjectType.eObjectType_nwOaPropertyVec)
nwProps1 = nwState.ObjectFactory(Autodesk.Navisworks.Api.Interop.ComApi.nwEObjectType.eObjectType_nwOaProperty)
nwNode = nwState.GetGUIPropertyNode(nwPath, True)
nwProps1.name = "Deneme_Name"
nwProps1.value = "Deneme_Value"
nwProps.Properties.Add(nwProps1)
nwNode.SetUserDefined(0, "User_Name", "Internal_Name", nwProps)
Next
End Sub
Daniel Kazado
Please use Accept as Solution if your question is answered.
You may Give Kudos if the answer is helpful.
4 REPLIES 4
could you debug the code to see what the failure is? particularly, adding Try-Catch clause to see more information, instead of crashing Navisworks directly.
I managed to do it with the help of your blog and this forum help of some more search. I also added to the end to search for the same name of PropertyCategory not to dublicate. I copy the code below for later reference for forum members. Thanks for your blog.
  Private Sub Button4_Click(sender As Object, e As EventArgs) Handles Button4.Click
        'COMAPI ile .net baglantisi
        nwState = Autodesk.Navisworks.Api.ComApi.ComApiBridge.State
        'create new Property Category Vector
        Dim newPvec As Autodesk.Navisworks.Api.Interop.ComApi.InwOaPropertyVec
        newPvec = nwState.ObjectFactory(Autodesk.Navisworks.Api.Interop.ComApi.nwEObjectType.eObjectType_nwOaPropertyVec)
        'create new property
        Dim newP As Autodesk.Navisworks.Api.Interop.ComApi.InwOaProperty
        newP = nwState.ObjectFactory(Autodesk.Navisworks.Api.Interop.ComApi.nwEObjectType.eObjectType_nwOaProperty)
        'set name, username and value of the new property
        newP.name = "Property_Name"
        newP.UserName = "Property_UserName"
        newP.value = "ProCS"
        'add the new property to the new Property Category
        newPvec.Properties().Add(newP)
        Dim oDOC As Autodesk.Navisworks.Api.Document
        oDOC = Autodesk.Navisworks.Api.Application.ActiveDocument
        'add property category to each item selected
            'select path of the item
            Dim oItemPath As Autodesk.Navisworks.Api.Interop.ComApi.InwOaPath
            oItemPath = Autodesk.Navisworks.Api.ComApi.ComApiBridge.ToInwOaPath(oItem)
            'select Property Category from path
            Dim PropCat As Autodesk.Navisworks.Api.Interop.ComApi.InwGUIPropertyNode2
            PropCat = nwState.GetGUIPropertyNode(oItemPath, True)
            'check each PropertyCategory Attribute to find same user_name
            Dim PropCatAtt As Autodesk.Navisworks.Api.Interop.ComApi.InwGUIAttribute2
            Dim checkAtt As Boolean = False
            For Each PropCatAtt In PropCat.GUIAttributes()
                If PropCatAtt.ClassUserName = "ProCS" Then
                    checkAtt = True
                    Exit For
                End If
            Next
            'if the PropertyCategory does not exist add it
            If Not checkAtt Then
                PropCat.SetUserDefined(0, "ProCS", "ProCS", newPvec)
            End If
        Next
        MsgBox("PROPERTIES LOADED UNDER ProCS TAB", MsgBoxStyle.OkOnly)
    End Sub
Daniel Kazado
in reply to: danielkazado
Hello All! Please tell me сan I do this using the API c#
Rail Community
