Navisworks API
Active Contributor
danielkazado
Message 1 of 5 (460 Views)
Add PropertyCategory and DataProperty with .NET using COM API
460 Views, 4 Replies
12-09-2013 12:12 AM
     I am using Navisworks Manage 2014 and try to load new PropertyCategory and DataProperty to the selected items. I try to do it with a Plugin and Button4 in the Form shall load new PropertyCategory and DataProperty to the selected items.
     I get most of the information for the code from "http://adndevblog.typepad.com/aec/2012/08/addmodifyremove-custom-attribute-using-com-api.html"
     Find below my code for the button below, when I try to use it in Navisworks it gives error and close. Any advice ?
Private Sub Button4_Click(ByVal sender As Object, e As EventArgs) Handles Button4.Click
Dim nwState As Autodesk.Navisworks.Api.Interop.ComApi.InwOpState10
Dim nwPath As Autodesk.Navisworks.Api.Interop.ComApi.InwOaPath
Dim nwNode As Autodesk.Navisworks.Api.Interop.ComApi.InwGUIPropertyNode2                                    'PROPERTY CATEGORY
Dim nwProps As Autodesk.Navisworks.Api.Interop.ComApi.InwOaPropertyVec                                          'DATA PROPERTY LISTESI
Dim nwProps1 As Autodesk.Navisworks.Api.Interop.ComApi.InwOaProperty                                              'DATA PROPERTY
Dim nwDOC As Autodesk.Navisworks.Api.Document
nwDOC = Autodesk.Navisworks.Api.Application.ActiveDocument
Dim oItem As Autodesk.Navisworks.Api.ModelItem
For Each oItem In oDOC.CurrentSelection.SelectedItems
nwState = nwDOC.State
nwPath = nwState.CurrentSelection.Paths(1)
nwProps = nwState.ObjectFactory(Autodesk.Navisworks.Api.Interop.ComApi.nwEObjectType.eObjectType_nwOaPropertyVec)
nwProps1 = nwState.ObjectFactory(Autodesk.Navisworks.Api.Interop.ComApi.nwEObjectType.eObjectType_nwOaProperty)
nwNode = nwState.GetGUIPropertyNode(nwPath, True)
nwProps1.name = "Deneme_Name"
nwProps1.value = "Deneme_Value"
nwProps.Properties.Add(nwProps1)
nwNode.SetUserDefined(0, "User_Name", "Internal_Name", nwProps)
Next
End Sub
Daniel Kazado
Please use Accept as Solution if your question is answered.
You may Give Kudos if the answer is helpful.
I managed to do it with the help of your blog and this forum help of some more search. I also added to the end to search for the same name of PropertyCategory not to dublicate. I copy the code below for later reference for forum members. Thanks for your blog.
 Private Sub Button4_Click(sender As Object, e As EventArgs) Handles Button4.Click
'COMAPI ile .net baglantisi
nwState = Autodesk.Navisworks.Api.ComApi.ComApiBridge.State
'create new Property Category Vector
Dim newPvec As Autodesk.Navisworks.Api.Interop.ComApi.InwOaPropertyVec
newPvec = nwState.ObjectFactory(Autodesk.Navisworks.Api.Interop.ComApi.nwEObjectType.eObjectType_nwOaPropertyVec)
'create new property
Dim newP As Autodesk.Navisworks.Api.Interop.ComApi.InwOaProperty
newP = nwState.ObjectFactory(Autodesk.Navisworks.Api.Interop.ComApi.nwEObjectType.eObjectType_nwOaProperty)
'set name, username and value of the new property
newP.name = "Property_Name"
newP.UserName = "Property_UserName"
newP.value = "ProCS"
'add the new property to the new Property Category
newPvec.Properties().Add(newP)
Dim oDOC As Autodesk.Navisworks.Api.Document
oDOC = Autodesk.Navisworks.Api.Application.ActiveDocument
'add property category to each item selected
'select path of the item
Dim oItemPath As Autodesk.Navisworks.Api.Interop.ComApi.InwOaPath
oItemPath = Autodesk.Navisworks.Api.ComApi.ComApiBridge.ToInwOaPath(oItem)
'select Property Category from path
Dim PropCat As Autodesk.Navisworks.Api.Interop.ComApi.InwGUIPropertyNode2
PropCat = nwState.GetGUIPropertyNode(oItemPath, True)
'check each PropertyCategory Attribute to find same user_name
Dim PropCatAtt As Autodesk.Navisworks.Api.Interop.ComApi.InwGUIAttribute2
Dim checkAtt As Boolean = False
For Each PropCatAtt In PropCat.GUIAttributes()
If PropCatAtt.ClassUserName = "ProCS" Then
checkAtt = True
Exit For
End If
Next
'if the PropertyCategory does not exist add it
If Not checkAtt Then
PropCat.SetUserDefined(0, "ProCS", "ProCS", newPvec)
End If
Next
MsgBox("PROPERTIES LOADED UNDER ProCS TAB", MsgBoxStyle.OkOnly)
End Sub
ADN Support Specialist
xiaodong.liang
Message 2 of 5 (437 Views)
Re: Add PropertyCategory and DataProperty with .NET using COM API
12-11-2013 01:09 AM in reply to: danielkazado
could you debug the code to see what the failure is? particularly, adding Try-Catch clause to see more information, instead of crashing Navisworks directly.
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
Active Contributor
danielkazado
Message 3 of 5 (430 Views)
12-11-2013 06:34 AM in reply to: xiaodong.liang
                    checkAtt = True
                    Exit For
                End If
            Next
            End If
        Next
    End Sub
Daniel Kazado
Evgueny
Message 4 of 5 (282 Views)
01-29-2014 08:38 PM in reply to: danielkazado
Hello All! Please tell me сan I do this using the API c#
Evgueny
Message 5 of 5 (277 Views)
01-29-2014 10:04 PM in reply to: Evgueny
