Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Images in Report
10 REPLIES 10
Message 1 of 11
rogeranda
1709 Views, 10 Replies
Images in Report
How can I capture images for report?
If I go to Default settings/Report Generation, all Capture image buttons is deactivated.
Is there some settings that can activate Capture buttons?
Roger Anda
10 REPLIES 10
Message 2 of 11
AndrewSears
in reply to: rogeranda
Roger,
We are looking into this.  More details to come.
thanks for letting us know about this.
Andy
Message 3 of 11
in reply to: AndrewSears
Hi Andy,
Any update on this?
I'm having the same issue for all of the report generation - capture image settings.
Ben
Message 4 of 11
Any update on this topic. current build of Nastran 2018 still seems to have this issue.
Message 5 of 11
John_Holtz
Hi @Anonymous
It appears that the "capture image" functionality has not been developed yet. Those commands are disabled in 2019 also.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Message 6 of 11
in reply to: John_Holtz
Dear John,
This is quite disappointing, this functionality existed in Simulation Mechanical. We have been forced to start using Nastran due to end of life of Simulation Mechanical. But the functionally seems to be quite lacking when comparing the two, and to make the results reports our customers expect we now have to use workarounds to get the result images.
I wonder how other user see this.
Message 7 of 11
shigeaki.k
Hello @Anonymous,
we empathize  with your frustration with the workflow and have informed the Product Team of the matter.
Shigeaki K.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Shigeaki K.
Technical Support Specialist
サポートとラーニング | Support & Learning
Message 8 of 11
Is there any progress on this.
It seems especially important to be able to show Safety Factor in the report(s) however it seems no way at point to do this.
Message 9 of 11
A way to size the images in the report is very much needed.  Plotting to fit makes the images fit resulting in text that is too small to read
Message 10 of 11
I see this is an old thread. Looking for the solution for sizing the images in the report and did not find a solution so far.
Did Autodesk solve the image sizing problem so that a report can be read normally or save as a PDF?
Message 11 of 11
boris.adum
in reply to: boris.adum
I found a manual way of adjusting all the images and it takes a minute or less, of there is a smarter way please share.
I just open the .html file in a text editor and replace all occurrences of string
.jpg" border=1
with
.jpg" border=1 width="1500"
